Orbi WiFi 7 RBE973
Reply
Security vulnerability in Orbi RBR20?
Wulff
Recently bought a RBR20 with one month Netgear Armor activated.
Today I received messages from my Synology NAS that it blokked the RBR20 ipaddres because of to many wrong logon attempts.
It seems the router has been hacked, what can I do about this?
Regards Fred
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Security vulnerability in Orbi RBR20?
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
Regards Fred
Message 5 of 6
All Replies
schumaku
Guru
No worries, the Netgear Armor does run the (Bitdefender based) vulnerability scan on a regular base against all LAN IP addresses.
You might want to lower the NAS intrusion prevention settings, avoiding the block and reports.
Message 2 of 6
Wulff
Thanks, this is a relief, I will try this when I get home.
Message 3 of 6
schumaku
Guru
Not fluent enough on Armor/Bitdefender - probably there are ways to exclude a LAN IP address from the scan. Haven't spotted an quick solution yet.
Message 4 of 6
Guru
Good Luck.
Regards Fred
Message 5 of 6
Wulff
Ok done, thanks.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1167 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
