Reply
Highlighted
Security
I activated security inadvertantly.  Now my cameras cannot get thru Port 85 and I cannot see them when Ieave my home network.  How can you turn Security back off?
Model RBR50, not Availble above
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Highlighted
Guru
Re: Security
By the same way you activated it I presume.
What did you activate? Parental controls? Circle? Armor?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 4
Highlighted
Re: Security
There is no way to turn it back off and reset it.  Even you disable Netgear Armour, is still says activated on the main Security page.
Message 3 of 4
Highlighted
Guru
Re: Security
Factory reset the RBR and setup from scratch. Don't enable it during the setup process.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 393 views
  • 0 kudos
  • 2 in conversation
Announcements
