Discussion stats
  • 1 reply
  • 233 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Selection 5 ghz vs 2.4ghz
Is there a way to select a device to be connected to 5ghz vs 2.4ghz? Or other way around? TIA
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Highlighted
Guru
Re: Selection 5 ghz vs 2.4ghz
The Orbi is designed to automatically select a frequency based on what client devices support and signal range and quality with the device...
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
