Orbi WiFi 7 RBE973
Reply
Setup PnP connection between Etisalat and Orbi RBK50
Fuzz_90
Greetings,
I recently purchased the RBK50 and faced an issue with conectivity. I did everything according to the steps but still couldn’t get an internet connection going. I even tried switching to PPPoE and entered the username and password, in addition, I enabled the Vlan bridge and entered my Vlan ID. After that, even the orbilogin website won’t open and i have to reset my router to factory settings. Does anyone have any idea what i’m doing wrong?
FW: V2.3.1.44
ISP: Etisalat
Plz help...
Message 1 of 3
Chuck_M
Mentor
Re: Setup PnP connection between Etisalat and Orbi RBK50
Sounds like you have a lot going on there... and one of the best clues was your comment about your Vlan ID.
Can you tell us the specific equipment your Orbi is plugged into? (Make/Model)
Can you tell us more about how your Vlan was configured?
When your system did work, how was it configured?
Message 2 of 3
Fuzz_90
I got the RBK50 AC3000 hooked to Alcatel-Lucent ISP ONT (cannot change)
I called my ISP and they gave me the Vlan ID which i entered in the orbi configuration setup but still did not work. So I basically configured my orbi to access point setup and hooked it up to my d-link AC1300 using an ethernet cable.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1293 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
