- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi!
Where is the signal strongest on the RBK50 mesh router/satellite? Due to the cables I have my master satellite with the frontside facing into a wall, the cabel connection side facing the room. Is that a problem?
Regards
Leif
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@LeifA wrote:Where is the signal strongest on the RBK50 mesh router/satellite? Due to the cables I have my master satellite with the frontside facing into a wall, the cabel connection side facing the room. Is that a problem?
It is not a problem. Not particularly "attractive", but functionally exactly the same.
The FCC filing for the RBR50 shows the pair of user device dipole antennas which are vertical on the left and right side of the chassis.
https://fccid.io/PY316200341/Internal-Photos/Internal-Photos-RBR50-RBS50-rev-pdf-3926901.iframe
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Signal direction on RBK50
I won't think this is a problem since the sat probably uses some sort of omni directional signal.
Using the pc login you can monitor what devices are going through the sat and keep an eye on their performance
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No. Just placement is and distance is key.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
@LeifA wrote:Hi!
Regards
Leif
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank's!
Then I can keep it facing the wall. Not estetichal but necessary due to narrow shelf.
Leif
