- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have a regional ISP, SuddenLink, and the router that was issued with this service is an ARRIS DG1660A/SL. Roughly 5 months ago, now, I purchased and installed an ORBI RBK50 Router and Extender (satelite). Since then, I have experienced dropped network for a myriad of items in the house (thermostat, MyQ garage door opener, gaming consoles, laptops, etc). But, have also expereinced intemittent wired connection for our game room Xbox One X. That is, we have a wired connection, that at times, will not connect, and the only way to connect is to go wireless. Then, at times, the wireless will not connect, and we plug the ethernet cable back in.
All of the issues are ocurring once we installed the ORBI. I can gather, from the many mediums for such complaints, or voiced issues, that there are some settings that must be figured out. Unfortunately, most people talk about chainging settings, but have been unable to address, in detial, how one does so. Can anyone help me to understand what I need to do? I love the network strength, when the mesh works....but, am not a fan of the way our network works in totality, since installing the Orbi system.
My house is 2400 sq ft, so should have more than enough mesh coverage...just, certainly seems to me, that the setting are in need of some changes to hopefully allow this set up to work.
Thanks in advance....
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, so not sure I can speak to all that was brought into play, above. But, I did log in to the admin portal for my Arris Touchstone Gateway, and disabled the wireless on both the 2.4GHz and the 5GHz bands. After doing so, and resetiing all (router/gateway, the Orbi R and Orbi S), all seems to be working, now.
The proof will be in if the intermittent nature of the service happens, again.
Thanks for your input and I will look further upon/if more interruptions in service continue. At this time, the Xbox is connected via Ethernet, the thermostat is online, the garage opener is online, as well as my work and home PC's.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Since Installing Orbi, multiple network issues...Wired & Wireless
If your modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hopefully thats all that was needed. Ya, if the modems wifi was enabled, then this was probably causing noise and some interferences.
Please mark your thread and solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well, I just returned home, and both my wired Xbox and my Wired PC were showing no connection. I am at a complete loss.
If my only measure, thus far, was to disable the wifi from the Arris Gateway/Router, is there any logical next step to remedy the issue? That is, by my wired connections being intermittent, would this point to another adjustment on the gateway, the Orbi, or both, in someone's estimate or experience?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So more than disabling of the modems wifi maybe needed, Review the suggesions for having a modem and router built in. Try option #1 first, if not then #2. #3 is the easiest...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
They work well when they are the only central wifi system. However the main issue is that you have a double nat condition which isn't normal or recommended. Having two routers on the same line can cause problems like what your seeing.
So the 3 suggestions are there to help clear this condition and most cases resolves problems like what your seeing.
