Orbi WiFi 7 RBE973
Reply
Sky + HD box crashes Orbi RBR40
Bigleemo
My Orbi RBR40 crashes / reboots everytime I try to download a tv program to my Sky + HD box. It doesn’t matter if the Sky box is connected via cable or wireless the Orbi still reboots. My Orbi is running firmware 2.2.1.210. Please help.
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 11
Guru
Re: Sky + HD box crashes Orbi RBR40
Have you tried to upgrade the firmware to the released 2.3.0.28?
https://www.netgear.com/support/product/RBK40.aspx#download
Message 2 of 11
Bigleemo
Thank you for your help. I Updated to 2.3.0.28 this morning so Let’s see if this update helps.
Message 3 of 11
Is that Sky thing also a router?
Message 4 of 11
Guru
After the update, if you didn't, reset the router to factory defaults and then reset it back up.
Message 5 of 11
Guru
Message 6 of 11
Bigleemo
No it’s just a Sky Tv box.
Message 7 of 11
Bigleemo
Internet router connected to Netgear Orbi is standard router supplied by plusnet. Manufacturer is Sagemcom, couldn’t find a model number.
Message 8 of 11
Guru
Need to check to see if the ISP Modem has a built in router. That why we ask for the model#. If it does have a built in router already...
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option#2 if you have access the modems web page. If not, then try option #3.
Message 9 of 11
Guru
Modem Combo Units:
Dang you typed that fast. Was in process of asking about if its combo device but couldn't type fast enough!
Message 10 of 11
Guru
Copy and paste is fast too. Smiley Very Happy
@plemans wrote:
Modem Combo Units:
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2522 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
