Orbi WiFi 7 RBE973
Sky Q and orbi
Neel1994
Tutor
Sky Q and orbi
Hi chaps.
So I recently purchased an orbi and everything is running great! Apart from my damn sky Q!!
The main box keeps disconnecting from the Orbi and I’ll get an X next to the network settings on the Sky Q... it doesn’t reconnect and I then have to re enter the password etc to get it back up and running and then BAM, it disconnects again.
Any suggestions from anyone using the Sky Q with an Orbi?
My orbi is set up in AP mode.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 9
Guru
Re: Sky Q and orbi
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 9
Neel1994
Tutor
Re: Sky Q and orbi
Well tbh I think I’ve found the problem....
My router is on the second floor of my 7000sqft home and my satellite 1 is in my kitchen where the main sky box is. The problem I’m seeing is that on the orbi admin page I can see my sky box is connecting direct to the router?!?! Why is this? It is way too far away to have a stable connection. How can I get it to connect to my satellite instead?
Message 3 of 9
Guru
Re: Sky Q and orbi
Had you tried rebooting the Q device to see if it will connect to the satellite?
Can also try rebootting the router while leaving the satellite and Q online and see if the Q will connect to the satellite.
How close is the Q to the satellite?
Does the Q have a RJ45 port in back?
Message 4 of 9
Neel1994
Tutor
Re: Sky Q and orbi
Okay so my house is 7000 sq ft. The router is an EE 4G router. The orbi is in AP mode.
The sky q can be connected via wired but this isn’t possible. The thing is my smart tv will connect to the satellite but the sky Q decides to jump to the router after 15 mins of being connected to the satellite. Everything else remains connected to the satellite.
I also don’t understand how I have a poor backhaul for my satellite status as it changes from good to poor every few days and vice verca. And I’m receiving 200MB DL from the satellite which is same as when I’m connected to router. So I’m not sure if the status is a glitch. There is no residents causing interruption. I live on 3 acres of my own.
I’d say the satellite is about 30ft exactly. Though I do have pretty concrete walls.
What baffles me is that the satellite is in the same damn room as the Sky Q !! So why would it want to jump all the way to the router which is pretty far away. Is there a setting where I can stop this from happening?
Message 5 of 9
Guru
Re: Sky Q and orbi
I presume there maybe a wifi issue at the Sky Q device.
I would contact the Mfr and ask for some information regarding it. Check to see if the wifi drivers on it are up to date...
 Try setting the power level on the routers wifi from 100% to 75 or 50%...
Message 6 of 9
Neel1994
Tutor
Re: Sky Q and orbi
I will try lowering the power as you’ve said.
Does this only reduce the power of WiFi emitting on the router alone? Or does it effect the power of the satellites as well?
Message 7 of 9
Guru
Re: Sky Q and orbi
I think it's only just the router...Let us know how it goes...
Message 8 of 9
Caroline285
Initiate
Re: Sky Q and orbi
@Neel1994 wrote:
Hi chaps.
Did you find any solution to this?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 7535 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
