Orbi WiFi 7 RBE973
Reply
Slow Download speed RBR50
OrbiMakeMeSad
Another sad case of slow download speeds. This is over a wired connection. Straight from WIN10 PC to RBR50v2 (Firmware V2.5.1.8). I can plug WIN10 PC straight into the drop from the ONT and get my full 300 up/down. When i plug same cable back into RBR50 I get 80s or 90s up and down. I did a factory reset...this solved the issue for about 2 hours and now i'm back to the slow speeds. I contacted frontier and of course they say nothing is wrong and i believe then since i can plug straight into the drop and get my 300 up and down. SOMETHING IS WRONG WITH THIS DEVICE. I'm using the embedded speedtest function and other sites. It's not "the wrong speed test".
I have no DMZs, VPNs, parental controls, (even turned off Armor). I changed DNS to 8.8.8.8 and back to ISP DNS. No change on either setup.
Please help me. I'll post logs or screenshots or whatever.
Thank you.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Slow Download speed RBR50
Is the Orbi system operating in Router or AP mode?
Does the RBR still experience the slow down if the RBS is turned off?
Try more recent version of FW:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/tru...
Message 2 of 4
OrbiMakeMeSad
I updated to 2.5.1.16. Speeds when back up to 300 up and down. For about 3 hours. Now I'm back down in the 80s. Both of the RBS are turned off. Then always show good signal when on though. About 25 feet away. This isn't a wireless issue. This is a wired connection
Message 3 of 4
Guru
You might contact NG support and ask for additional help with this...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 739 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
