Orbi WiFi 7 RBE973
Reply
Slow LAN Speed
Yerky
Tutor
Slow LAN Speed
I just recently installed the RBK50 for my home internet. When I plug directly into the router and run a speed test on my computer, I average between 300-500MBps. When I unplug the Orbi router from my modem and plug my computer directly into the modem, I average between 900-950MBps. I am on the latest firmware on the router and everythig works better than expected other than the troughput. Is there some setting to allow full service throught the LAN ports?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 9
Guru
Re: Slow LAN Speed
What FW is currently loaded?
Try a reset on the Orbi router and this time, don't enable QoS, Traffic Meter or Access Controls.
Has nothing to to with LAN port speeds.
Message 2 of 9
Blanca_O
NETGEAR Moderator
Re: Slow LAN Speed
Hi @Yerky
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 3 of 9
Yerky
Tutor
Re: Slow LAN Speed
The Orbi is connected to my Ubiquiti edge router which is connected to my Arris SB8200 cable modem. The port on the router it is connected to has no blocking service on it and was previously used by my R8500. With the nighthawk, I was only able to get consistent speeds of around 900-925Mbps. With the Orbi, it is exteremly rare to see speeds above 400Mbps.
Currently, the Orbi router is setup with no traffic metering or even QoS and the FW is version 2.2.1.210. I updated the FW to try and fix all the random internet drops throughout the day.
Message 4 of 9
Guru
Re: Slow LAN Speed
Is the Orbi system operating in Router or AP mode? If router mode, try AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Message 5 of 9
Costa_Levine
Re: Slow LAN Speed
Same issue here, My ISP provides 1 Gbps down/up.
When connected directly (wired) to the ISP router I get ~800-1000 Mbps
When connected to the Orbi's LAN I get ~500mbs download and 934mbps upload.
Same results in the internet speed in Orbi android app.
Tried both: Router and AP modes. Same results.
*Firmware version: v2.2.1.210
Any updates about this slow LAN performance issue?
Thanks
Message 6 of 9
Guru
Re: Slow LAN Speed
Does your ISP use PPPoE or DHCP for there services to your modem?
There is more recent FW that you can try:
https://community.netgear.com/t5/Orbi/New-NetGear-Orbi-RBR50-RBS50-Firmware-Version-2-3-0-32-now/m-p...
If you do, upate the Satellites directly to v32 first, then, update the RBR to v212 first, then apply v32. v212 is required before v32 can be applied on the RBR.
Thanks
Message 7 of 9
Costa_Levine
Re: Slow LAN Speed
I changed cables and tried to use another laptop and I started to get ~800-1000 Mbps on download.
Not sure what's going on with the internet speeds in the android app.
So, my issues resolved for now.
Thanks for the quick response @FURRYe38
Message 8 of 9
Guru
Re: Slow LAN Speed
Enjoy. Smiley Wink
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2291 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
