Orbi WiFi 7 RBE973
Reply
Slow Max Wifi Speed or incorrect wifi setting?
dan801
Apprentice
My wifi settings seem to be in-correct or not properly configured. The maximum speed i'm able to achieve on the 5g frequency is only 866mhz and I thought this should be a lot higher? I also can't select the higher level channels in 5g which seems to be part of the problem? Anything I can do to fix this? RBK50
My wifi settings are showing the following;
2.4G Channel 6(P)+10(S)
2.4G Mode Up to 400 Mbps
5G Channel 36+40+44+48(P)
5G ModeUp to 866.7 Mbps
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
ekhalil
Master
Re: Slow Max Wifi Speed or incorrect wifi setting?
1. What speed do you get for wired devices?
2. What wireless device did you use to get the measurements above?
3. Please activate MU-MIMO in the advanced settings and see if this will give improvements for wireless devices.
4. Please make a wifi scan and select a better 5GHz channel that the one you’re currently using if possible. The upper 5GHz channels are reserved for the backhaul link only.
Message 2 of 3
ekhalil
Master
@dan801 wrote:
........ The maximum speed i'm able to achieve on the 5g frequency is only 866mhz ......
If you mean that you're getting 866 Mbps with wireless devices then you're really getting the maximum that you can get out of Orbi.
Please see attached table showing the possible bit rates in Orbi depending on the number of used spacial streams (no, dual or multiple MIMO), channel bandwidth (20, 40 or 80 MHz) and the radio conditions.
The maximum possible rate that you can get from Orbi is 866.7 if using dual MIMO, 80 MHz channels and with best radio conditions (MCS 9).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1195 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
