- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Slow Speeds
Hi,
I have Xfinity gig service and have recently had a tech here to confirm speeds coming into the house (1.07 gb/s). I have a Nighthawk CM1200 modem feeding my Orbi system. I am receiving no more than 250 mb/s anywhere in my house so I'm wondering if my setup/configuration is wrong. Can anyone give some guidance?
Thanks!
Erik
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow Speeds
Are you seeing near 900Mbps with a wired PC connected directly to the CM modem with out the RBR in the middle?
What device are you speed testing with? Some wifi devices will not speed test beyond 400-500Mpbs
What link rate are you seeing with a wifi device?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
