Orbi WiFi 7 RBE973
Reply
Slow WiFi speeds
Reisender1
Follower
Slow WiFi speeds
I have 1-RBR 50 and 2 RBS50s. Ookla Speedtest using iPhoneX at the RBR is 234/11.8.
I have 2 iMacs (one mid-2010 the other mid-2011)  in a different room @15 feet from the RBR. Ookla Speedtest using Ookla App on iMacs is @ 35.2/13.3 for the mid-2010 and 62.2/13.0 for the mid-2011. Any suggestions on how to solve this?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Slow WiFi speeds
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 469 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
