- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow Wifi Speeds using RBR50 and 2 RBS50 satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running a Mesh system with a RBR50 router and 2 RBS50 satellites. Running latest firmware (I have checked for updates to confirm they are up to date). My cable internet connection is through Spectrum @ 400 Mbps. I am using a modem only (it is NOT a wifi router) so this is not a double NAT problem. Until a few weeks ago I consistently got 400+ Mbps on all my devices when using Speedtest over wifi. I noticed a slowdown so I checked and now I am only getting 30-40 Mbps. I did a speed check from the router using the Orbi app and it is showing a full 400 Mbps, so the problem isn't there. My desktop is plugged into the ethernet port on one of the satellites and it gets a full 400 also, so the problem is not with the backhaul either. I have tried checking and unchecking MU-MIMO, Beamforming, Daisychaining and there is no improvement when these are either on or off. I have tried speedtesting my devices in different parts of the house (approximately 3800 sq ft) and it is the same everywhere. Obviously I have rebooted the router and the satellites. I am at my wits' end. I searched the community without finding any solutions. Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow Wifi Speeds using RBR50 and 2 RBS50 satellites
v16 would be most current FW.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
