Orbi WiFi 7 RBE973
Reply
Slow download = Fast Upload
jdbauer6
Hi - using SpeedTest, I continually get around 40-60Mbps download vs. 150+Mbps upload.  I am on the latest firmware, and am on the 5G network on either the satellite or router - same speeds.
Any ideas on why this would be happening and potential fixes?   I've changed the 5GZ channels a few times with little change.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 10
jdbauer6
Re: Slow download = Fast Upload
..and one other thing - I hardwired to the FIOS router, and I get 150/150 - so that's not the issue.
Message 2 of 10
DarrenM
Sr. NETGEAR Moderator
Have you enabled beamforming or mumimo? also have you tried to re position your satellite?
DarrenM
Message 3 of 10
jdbauer6
Yes - I have tried with both of those settings on and off with little difference.  I have not moved the satellite around, as I get fast performance on upload, so that’s likely not the issue?
Message 4 of 10
DarrenM
Do you have orbi set up as a AP or in router mode? if in router mode do you have your FiOS router bridged?
DarrenM
Message 5 of 10
jdbauer6
It’s in AP mode.
Message 6 of 10
jdbauer6
Here are some sample tests over several days.  A couple of days had good upload/download, but almost all have significantly lower download than upload speeds.
Message 7 of 10
carbonyle
Similar issue here, I'd be interested to see if you fixed it
Message 8 of 10
jdbauer6
Unfortunately not.  Actually seems slower than before - household is complaining.
Message 9 of 10
bsantucci
Tutor
I experience the same thing.  I notice it on my phone a lot and it's happened across different phones, not just one type or manufacturer.  When I reboot the phone, though, I get full speed again.  Not sure what is causing the communication issue, but reboot always corrects it.  Been like this since I got the Orbi in May.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3243 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
