- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow speeds Dm200 with Rb50
- Mark as New
- Bookmark
- Subscribe
- Permalink
The speed coming into the modem is 50mbps yet the speed at the Orbi is only 32mbps.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow speeds Dm200 with Rb50
What mode is your modem working in? Router or modem only mode?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Are you testing wired or wireless speeds? Wired is preferred first.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
