Orbi WiFi 7 RBE973
Reply
Slow upload speeds with Orbi RBR50
GB_NET
If I run the speedtest from the QoS Setup page in the Orbi admin console, I get:
Download: 90.56 Mbps
Upload: 41.27 Mbps
If I run speedtest from my wirelessly connected Surface Pro laptop I get:
Download: 92.47 Mbps
Upload: 16.95 Mbps
My laptop is 4 metres from the router.
From talking to my ISP I should be getting speeds like those reported by the Orbi QoS speedtest.
A search suggested changing QoS settings at 192.168.1.1/QOS_main.htm.
However, attempting to do so returns a 400 bad request and the settings aren't changed.
Does anyone know why the upload speed from my laptop is half the speed and how this can be improved?
Thanks.
Message 1 of 9
Guru
Re: Slow upload speeds with Orbi RBR50
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try a different wireless device to compare upload speeds with.
Upload: 41.27 Mbps
Upload: 16.95 Mbps
Thanks.
Message 2 of 9
GB_NET
Thank you for your suggestions.
The firmware level is 2.3.1.48.
The modem is an Arris CM8200.
The distance between the router and satellite is just under 30 ft.
I've tried with two laptops. Both have been about 10 ft from the router (40 ft from the satellite).
I'm using Auto and 36. I've also tried channels 6 and 48 but this made no difference.
My laptops both use the 5 GHz channel.
I've used Acrylic to take a look at the channels being broadcast and I don't see any issues with neighbors etc. My channels dominate.
WPA2-PSK is configured.
As I said, the download speeds using speedtest.net on the laptops match with that reported by the router under the QoS settings so I would think that the wireless connections are fine.
I might try the advanced settings you suggested when I get a chance.
I would like to understand the upload speed discrepancy. This would help determine if there's a solution.
Message 3 of 9
GB_NET
Also, does anyone know if you can determine or specify which server the router uses for the speedtest?
Message 4 of 9
Guru
What does a mobile phone or pad result in for the upload speed?
Message 5 of 9
GB_NET
Thanks for your assistance.
I have a support ticket open with Netgear and they're getting me to try a few things.
Message 6 of 9
Guru
Ok, let us know how it goes. Let us know if any of the suggestions help as well.
Message 7 of 9
WHTMTN
Tutor
Did you ever find a solution for this? I am experiencing the exact same issue. Have tried playing with all of the settings but stilll slow on the upload.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 8 of 9
Guru
Any progess on this?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2994 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
