- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow wifi speeds Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Guys!
My first post, so not sure if I am addressing this correctly or not! But Ive started to experience slow wifi speeds over the last few weeks.
I have Virgin Media 350mbps using SuperHub 3 as Modem mode. However on the Orbi RBR50 Im getting speeds of upto 70mb. (Being right next to the Router, using Macbook pro2018)
Intially I thought the issue was with VM, so connected SuperHub3 Router mode and speeds went upto 280mb. (Same device and same distance)
I keep hearing about Advance Wireless Settings, but I was hoping if anyone could help here? Ive had the RBR50 since 2017 and never had issues before. Do I need to downgrade firmware? And if so (how?)
Many thanks!!!!
RBR50 Firmware v2.5.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow wifi speeds Orbi RBR50
if you'll do a search, you'll see that many have had problems Firmware v2.5.1.8
your best bet is to revert back to your previous version and STOP performing manual downloads
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your modem bridged? If your modem has a built in router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m...
Has a factory reset and setup from scratch been performed since last FW update? Try this before downgrading.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
@nabeelm wrote:Hi Guys!
Many thanks!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do you revert back to the previous Firmware to see if it corrects the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just download the prior version of FW files and manually apply them.
You should try a factory reset and setup from scratch before downgrading. This has helped others seeing problems.
Can try voxels FW aswell:
@tspoon wrote:How do you revert back to the previous Firmware to see if it corrects the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems complicated, not sure I can keep from screwing that up. I am only getting about 96 mdps down whcih is an issue correct? A Connecting directly to the RBR50, I get about 600 mpbs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where are you seeing this 96Mbps speed at?
Wired or wireless?
Are you connecting with the RBR or RBS?
@tspoon wrote:Seems complicated, not sure I can keep from screwing that up. I am only getting about 96 mdps down whcih is an issue correct? A Connecting directly to the RBR50, I get about 600 mpbs
- Mark as New
- Bookmark
- Subscribe
- Permalink
