Orbi WiFi 7 RBE973
Reply
Slowww Internet on Orbi RBR50 with 2 RBS50
Easleyga
Follower
For the last 3 months my wireless has been terrible. We have the Orbi RBR50 with 2 RBS satellites. If I connect directly to cable modem/wireless browsing works excellent but if I connect to Orbi system it is terrible slow if even allows me to browse. The system worked great when I first purchased. Any ideas?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
RogerSC
Virtuoso
Re: Slowww Internet on Orbi RBR50 with 2 RBS50
I'd suggest resetting all the units to factory defaults and then reconfiguring from the ground up via the regular Orbi configuration process. If you haven't done that in a while, there's a good chance that bringing the configuration of the wireless system back to your desired settings from the defaults may well get your system back to working well. At least you'll be closer to a reference state, and the results of doing this will tell you something, too.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 416 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
