- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Smart TV Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Smart TV Connection
I have a smart TV that is approximately 10 feet from my satellite. For some reason it continues to try and connect to the 2.4 GHz channel on my Orbi. There is a lot of lag in buffering. Any possible solutions to this problem? To clarify, the device that is buffering is actually an Amazon fire stick. It should take both 2.4 GHz and 5 GHz network's. Why would I try to connect to 2.4? And even though it is connected to two. 2.4ghz, why would the connection be so slow?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Smart TV Connection
What speed is your Internet ? Is there anything else around that would interfer with the signal ? If it is a Fire stick with Kodi that alone could be it. Give us some info.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try moving the satellite in relation to the Fire Stick and see if that helps. Try a few different locations closer and farther away, and at different angles.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my experience, Smart TV's have very lowend wifi chipsets - I try to avoid using it if possible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Drake. Your going to think I'm nuts, but are you using the extender with the fire stick ? If you ar etry removing it and plugging the fire stick straight into the HDMI Port.
All the Best,
glenee
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The power has to be there. I was talking about the short extender cable that comes in the box, the extender cable is used primarly for tight fit to certain TV's.
