× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 328 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Smart tv
My WiFi works but all the apps on my smart tv won’t connect to the internet and they won’t start but all my apps on my iPhone and iPad work except I can’t download any apps or update them
Message 1 of 3
Highlighted
Guru
Re: Smart tv
Is this in regards to an Orbi system or your TV and iPhone not working?
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
Guru
Re: Smart tv
What modem are you using?
What router are you using?
Firmware on router?
Are you running a modem/router combo device and an additional router? I've noticed on the forums that Apple has issues updating when you're in a double nat situation.
https://kb.netgear.com/30186/What-is-Double-NAT
CM1100->RAX200->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 3 of 3
