- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Solid Magenta daily drop out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every morning I awake to find my Orbi router has disconnected with a solid magenta light. Unplugging/plugging back in or a reboot resolves the issue temporarily.
I'm on firmware V2.5.1.16. I have restored to factory settings, disabled beamforming & MIMO and it doesn't make any difference. The logs don't show anything out of the ordinary. Any ideas what could be causing this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Solid Magenta daily drop out
Can you please describe how the Orbi is connected to the internet?
Cable/Fiber? Provider (Cox, Spectrum, etc...) and the brand and model number of ISP device?
Is there a definite pattern to the length of time between the restart and when the connection is lost?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi is connected to an NBN Arris CM8200 modem. I'm on a Telstra HFC plan (Australia).
The modem does not disconnect from the internet, only the Orbi drops out each day.
It's likely a 24 hour period between restart and a lost connection. I restart it each morning, it is fine during the day and early evening but has dropped out by the next morning.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jimmah82 wrote:The Orbi is connected to an NBN Arris CM8200 modem. I'm on a Telstra HFC plan (Australia).
The CN8200 is a straight ISP modem, so there should be no issues there. Do you have any sort of scheduling going on? Maybe a power issue? Have you rebooted the modem? If it is losing connection close to the same time every day, it is more of a setting than the Orbi itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jimmah82 wrote:It's likely a 24 hour period between restart and a lost connection. I restart it each morning, it is fine during the day and early evening but has dropped out by the next morning.
It would be useful to know "when" the internet connection fails. There are a number of "ping monitor" applications that will ping an external IP address at regular intervals and report when there is no response. I use EMCO Pint Monitor Free (because it is free) and set it to check Google DNS (8.8.8.8). Could check any IP address that responds to ping; I just happened to pick that one.
When the Orbi reboots and connects, the Orbi web interface, Advanced Tab Home screen, click on the box "Connection Status" and it will show how long the Orbi IP lease is for and when it will expire. If the connection drops exactly at the end of the DHCP lease, that would be useful information.
