Orbi WiFi 7 RBE973
Reply
[Solved] Case closed
KryptoMagus
Case closed because of stupid error on my end.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
KryptoMagus
Re: [Solved] Case closed
I was having problem with port forwarding. I have tried disabling upnp and it still doesn't work. After writing all the tests I have done, I found out that I set a static IP on the device and the gateway was set to my old router IP 192.168.1.254, instead of 192.168.1.1 I set on my Orbi.
Message 3 of 4
All Replies
Guru
Would be nice to know that the problem was.
Glad you figured it out though. Enjoy.
Message 2 of 4
KryptoMagus
Message 3 of 4
Guru
AH good to know. Thanks for letting us know.
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 743 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
