Orbi WiFi 7 RBE973
Reply
Specify the device to connect to
folletto
Hi there,
My setup is router (ethernet) sat1 (wireless) sat2. All devices are on the latest firmware (V2.1.4.16). The router is on the lower floor, the two satellites are on the upper floor.
The WIFI connection between the two floors is pretty bad, devices often loose connection. Nevertheless, some of my devices and even the sat2 connect to the router. This leads to poor performance on the wireless backhaul and many interruptions when using my Sonos Play:1, which is also located on the upper floor.
When sat2 is connected to sat1 the backhaul performance is twice as good (windows file transfer speed) and when the devices are connected to sat1/2 there are no interruptions.
Is there a way to "fix" a client device or the Orbi satellite to a specific Orbi device? Or do you have any other idea?
Thanks and cheers,
Markus
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 8
Cmo1
Apprentice
Re: Specify the device to connect to
As far as I can tell, and someone can correct me if I'm wrong, the satellites appear to simply be dummy devices. The only thing you can do with them is see what bands they are using and what devices are connected to them, but can't change anything. This also is something Netgear could easily fix by allowing us the option to choose what devices connect to what band and id. However, every time one of us raises one of these concerns, I don't ever see any Netgear folks chiming in as to why it isn't permitted or if and when it might be allowed or fixed. At this point, in the absence of any dedicated beta forum or a Netgear engineer who regularly monitors these forums it seems we have to rely on each other to fix and test a device we paid huge amounts of money for. It's completely unacceptable. If my company was run that way, we'd be out of business.
Message 2 of 8
Guru
Whats the distance between the router and satellite(s)? Starting should be about 30 feet in between depending upon building materials.
Whats the Sq Ft of your home?
Building materials the home is comprised of?
@folletto wrote:
Hi there,
Thanks and cheers,
Markus
Message 3 of 8
folletto
I should start on a drawing 😉
(upper floor, 900sqft) sat1  < 20 feet > sat2 (mostly dry wall inbetween)
concrete floor
(lower floor, 400sqft) router (about 13 feet away from sat1 + sat2)
Message 4 of 8
Guru
Starting should be about 30 feet in between depending upon building materials. Your satellites are too close to the router.
Your kind of sq ft, try using only the router centrally placed, it can cover up to about 30 feet radius. Then maybe add 1 satellite.
I would disable Daisy Chain and MIMO on the router as well...
Set manual channel 1, 6 or 11 on 2.4Ghz.
Message 5 of 8
folletto
Oh, I did not expect there is a "too close", I'll try to increase the space in-between the devices.
Unfortunately, I need all of my devices.
The router is close to my internet connection and the ethernet connection to the upper floor, sat1 is at the end of that ethernet connection, sat2 is where all my "entertainment" and my file server is and I need the build in copper ports ...
Just having a single WiFi AP would not work either, devices on the other floor will have connection issues (tested with the Orbi Router and another WiFi Router).
Message 6 of 8
Guru
Message 7 of 8
mith_it
Luminary
Hi, have you tried just keeping one satellite connected to the ethernet on the top floor?
With 900sqft you shouldn't have a coverage problem
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4630 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
