Reply
Specifying local DNS server
TheRoadRat
Initiate
On my network I have my own DNS server featuring some nice parental controls. I can specify this server as primary DNS server in the DHCP settings (Domain Name Server (DNS) Address). But Orbi will then pass on the router's ip as DNS server to DHCP clients and subsequently all DNS requests seems to origin from this router address from the DNS server's point of view.
Is it possible in the setup not to act as DNS proxy but rather pass on the custom DNS server specified to connecting DHCP clients?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Specifying local DNS server
I don't believe you can disable the DNS Relay on NG routers...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1153 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
