- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Speed When Connecting RBW30 to RBK/RBS50 Setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I currently have an rbk50/rbs50 combo setup. It works great, but there is one area where the signal is a bit weak. I was thinking about adding the rbw30, however I've read that it brings down the entire network to the speed of the rbw. Can anyone confirm whether or not adding the rbw30 brings the max speed of the rbk50/rbs50 down to that of the rbw30 or does it simply reduce the speeds of the devices connected to the rbw30, while still keeping the max speeds of the rbk50/rbs50 unchanged?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
throughput that may @AnthemDBA wrote:Hi,
Thanks
I have an RBK53 system and had an RBW30 in my living room. There was no degradation in my speed. The difference is the satellite has 866Mhz backhaul channel vs. 1733Mbps on an RBS50. Both are Tri-Band. So anything connected to the RBK30 will have a slower throughput, possibly make the devices have a slower WIFI connection.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Speed When Connecting RBW30 to RBK/RBS50 Setup
Great, thank you!
