Reply
Johan_E
Follower
Speed in a 1+3 setup RBR50
Hi
I have significant problems to get good speed from my Sattelites. The Router is an RBR50 and the sattelites is RBS50 (i think). When I test I get an access of approx 30Mbit on the wireless laptop connected to sattelite while the Router connection is 250Mbit. What can possibly be wrong and what to do about it?
Johan
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Speed in a 1+3 setup RBR50
Are you disabling the wifi devices wifi radio for 5 seconds, then go near the RBS, then re-enable the wifi radio on the device then speed test?
What devices are you speed testing with?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 65 views
  • 0 kudos
  • 2 in conversation
Announcements
