Reply
Exasketch
Follower
Speedtest Irregularity
I have a RBK23 mesh system newly purchased with the basic setup complete.
When I complete a speed test on the ORBI interface/console I get max download and upload speeds.
When I use speedtest.net through a browser which in the past gave me the same results, now drops my download speed by nearly a third of my connection speed
I am running on a eithernet connection directly pluged into my orbi hub/router
Can someone explain is this is suppose to be normal with Orbi or is something wrong.
Regards
Exa
Message 1 of 3
CrimpOn
Sensei
Re: Speedtest Irregularity
There have been numerous posts comparing Speedtest on the Orbi web interface with Speedtest on a device connected to the Orbi. I, myself, see no difference which may be a consequence of having less "raw speed" to begin with.  Now that gig internet connections are common,this seems to be reported a lot more.  I would say, "disappointing" rather than "something wrong."
What matters, of course, is the actual speed delivered to devices connected to the Orbi.
I love my Orbi.
Message 2 of 3
Guru
Are you checing speeds with a wired PC and Ooklas installable speed test app to compare? Browser can cause inaccrate speed results...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 73 views
  • 0 kudos
  • 3 in conversation
Announcements
