Reply
Stability AP vs Router mode on .18 release
ALNJ2017
Star
Does anyone have experience with moving the Orbi to AP mode
on the .18 release ?
Wondering if that is a temporary way to get some atability.
Just need a spare box for Router/NAT/DHCP.
any recommendations for a Router suitable for a high speed 200 Mbs plus cable modem are appreciated ?
Al-in-NJ
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 8
Accepted Solutions
ALNJ2017
Star
Re: Stability AP vs Router mode on .18 release
Ok will try setup as AP.
Al-in-NJ
Message 7 of 8
All Replies
Den_
Guide
I updated my Orbi to .18 yesterday. I run it on AP mode and before the update it would reset every few hours. Since the .18 update it has not reset once (just over 24h). I will keep an eye on it, but it seems a lot more stable. Also my Samsung galaxy s8 used to get authentication errors daily. I haven't had one of those either. I know it's not been running long, but it is a big improvement over all the other versions I have tried.
Message 2 of 8
Steven_Belfast
Apprentice
Cannot comment on the modem you could use but I have been using the Orbi RBK30 units in AP mode for many months and a number of firmware versions and it’s always been stable and great connection with great throughput speeds.
Have been on .18 for a few days and no drops in connection.
Message 3 of 8
timch
Luminary
Works perfectly for me in AP mode.
Message 4 of 8
linkwrt
Guide
I have RBK50 kit with 1000fiber and pppoe.
I have 950-960mbps on LAN
almost 600mbps on wireless with old macbook
same speed 500-600mbps on wireless from satellite RBS50 connected to RBR50 over wireless.
So, it support pppoe >900mbps.
Message 5 of 8
Wizec
Apprentice
We had a lot of issues using Orbi in Router mode with several recent firmware releases. The router continually dropped the Internet connection ( to AT&T UVerse DSL modem ).
After switching to AP mode, all of our Internet connectivity issues have vanished.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 6 of 8
ALNJ2017
Star
Al-in-NJ
Message 7 of 8
spewak
Luminary
Went to AP mode to support Bitdefender Box 2. Now that I configured the Box 2 correctly, the AP mode on router works well. No drops on any idevices or my Directv box.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3307 views
  • 1 kudo
  • 7 in conversation
Announcements
Orbi WiFi 6E
