Orbi WiFi 7 RBE973
Reply
Static ip for router and satellite
Samhk
Follower
I have recently bought a set of Orbi RBK50 package with one router and one satellite, and changed the ip of router to 192.168.18.1 and disabled its DHCP function. How can I set a static ip for the satellite with the same subnet 192.168.18.x?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Accepted Solutions
CrimpOn
Guru
Re: Static ip for router and satellite
Orbi satellites get the IP address using DHCP.  If the Orbi is not providing DHCP, then whatever device is providing DHCP needs to have their MAC addresses in the table with IP assignments.  If the network has no DHCP server (which seems unusual), Orbi satellites won't work.
Message 2 of 2
All Replies
CrimpOn
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3355 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
