- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Sticky connection and preference for 2.4ghz
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why can't the Orbi system let users choose their preferred band of connection? I am sick of having my devices stucked on 2.4ghz and suffering at less than half of my ISP speed and high ping. Devices also seem to try their best to "stick" to the furthest node! I tried many things like reducing the 2.4 ghz power to 25%, disable/enable daisy chain, enable/disable beamforming, enable/disable MUMO, enable/disable fast roaming, factory resets, syncing the satellite and router, power cycle etc. Can't understand why devices still prefer 2.4 after all these! I can't disable 2.4 as I have some devices that need it. However, the Orbi should let users choose specific devices to connect to 5ghz as priority. I don't mind the split second of lost connection when roaming if all of my 5ghz devices will connect to 5g and I don't have to suffer significantly reduced isp speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Sticky connection and preference for 2.4ghz
Not exactly a point-and-click solution but it will work, apparently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I would prefer if Netgear implement this into the router configuration page then to rely on third party solution. I had the Velop before this. I was able to set different SSID with the velop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I hear that and completely understand and emphathize, but then I'm still hoping NG implements an option to disable auto-updating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
