- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Stuck in the middle?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've one satellite, about 30ft away from the base. My system is very stable now under 2.4.1.16.
But, one odd thing I see is in my home my bedroom is about half way between the 2 units, and when I use my lenovo yoga book tablet in the bedroom the connection drops and reconnects every few minutes. Streaming is not interrupted, but I get disconnect and reconnect messages. This doesn't happen anywhere else!
So I am thinking the tablet may be swapping continually between satellite and base. Would that make sense in explaining the drops and reconnects?
So is there a stuck in the middle issue? and any settings I can tweak to prevent this?
Daisy chain off
MIMO off
Fast roaming off
Daisy chain off
all transmit powers at 100%
20/40 Mhz coex on.
2.4 channel Auto
5 channel 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Stuck in the middle?
Try manual channel 1, 6 or 11.
IF this is the only device doing this, maybe something with the device thats not working well with the orbi.
As a test, turn OFF the satellite, does this device keep connected or still lose connection?
Does the device do this closer to the satellite?
Sate the system been powered OFF for 1 minute then back on after the FW was updated?
- Mark as New
- Bookmark
- Subscribe
- Permalink
In general, you should set the router manually to channel 1, 6, or 11 on 2.4 GHz.
Yes, this can happen if devices are right in the middle.
You could move either the router or the satellite, so one is stronger in the bedroom.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Well, I changed the channel to 6 and it seems to have stopped the disconnect and reconnect. Thanks for suggestion.
Looks like the satellite hooked into more wireless devices as well.
Couple of observations:
1) the satellite now shows up in router as a connected device, not as a connected satellite
2) satellite stays on channel 13. I am assuming this is 'cos i haven't rebooted the satellite after changing to channel 6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try rebooting the satellite, then the router and let it come to ready. Should appear as a connected satellite...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did all the reboots etc... So then the disconnects went away but has been replaced with buffering on video and audio streaming. Tried to set it all back to what is was, but can't stop this buffering.
So, given up now on using Orbi as a router and switched to AP mode. So far, that seems to have fixed it all up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
