Reply
Highlighted
Switch from 5ghz to 2.4ghz
I actually have an Orbi RBR40 with 2 RBR20 Satellites and I'm trying to link my greenie lights to my network. My satellites and phone are both on the 5ghz band. I reset my bulbs and they are blinking fast but as soon as I try to link them it tells me to change to a 2.4ghz network but I see nowhere to do that as both are combined in the Orbi mesh network. (they aren't named differently like other routers are). Anyway, the bulbs won't connect and I get the message to switch to 2.4ghz network. Can anyone tell me how to get it to connect on 2.4? Thank you in advance! Scott.....
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Highlighted
Guru
Re: Switch from 5ghz to 2.4ghz
Disable the 5Ghz SSID broadcast Under Advanced Tab/Advanced Settings/Wireless Settings
There will be a check box there, uncheck it and save settings. Re-check it after you have setup your devices.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 8
All Replies
Highlighted
Guru
Message 2 of 8
Highlighted
Sorry guys,, nding my question. I found the link on how to do it and am working on it right now. Thanks again! Scott.....
Message 3 of 8
Highlighted
Guru
Enjoy. Smiley Wink
Message 4 of 8
Highlighted
Thanks! Scott.....
Message 5 of 8
Highlighted
Guru
Smiley Happy
Message 6 of 8
Highlighted
A thousand times thank you! I got mine hooked up and was loving it I tried to add my 2.4 switches. I saw the Telnet fix but didn't want to go that route (yes,a router pun). Found this and now I'm good to go!
Message 7 of 8
Highlighted
Guru
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 15828 views
  • 1 kudo
  • 3 in conversation
Announcements
