Orbi WiFi 7 RBE973
Reply
The devices connect via wifi to RBK50, but some show no internet connection.
Tigana
SInce a couple of weeks I have got problems with my Orbi router. Devices connect easily, but some does not get internet connection, while some work fine. E.g. my iMac most often shoe no internet connection when starting from sleep. Turning of and on WiFi will after a whil solv the problem, but it may take 20 times or more. Most often I get a connection for a second or so and then it goes down again. This repeat quite often. On the other hand my AppleTV typically connects to internet all the time.
I have restarted the router several times and I have also, for other reasons, replaced my fiber node for higher internet speed, but the
problem with the router remains unchanged.
Any idea of what to do. It is quite annoying, as the router worked very well until just a couple of weeks ago.
I have also changed the firmware to tha latest, without any improvements.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: The devices connect via wifi to RBK50, but some show no internet connection.
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 6
All Replies
Guru
Message 2 of 6
tomschmidt
Virtuoso
By "latest" firmware, are you running v2.5.1.8 firmware? See https://www.netgear.com/support/product/RBK50.aspx#download for the latest for your RBK50 router and satellite.  Be sure to upgrade the satellites first.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 3 of 6
Tigana
Thanks for your comments. I now have made a factory reset and so far so good it seems to work. 🙂
Message 4 of 6
Tigana
Thanks for response. Yes I have that firmware, however I updated the router with the software and the satelite updated automatically.
I have now also made a factory reset and reconfigured the router. It seems to work for now.
Message 5 of 6
Guru
Be sure to do a backup configuration to file for safe keeping and use later on.
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3149 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
