Orbi WiFi 7 RBE973
Reply
This NETGEAR device is already registered with another account
successhawk
Follower
I have the exact same problem, and I see there was no resolution.
I never tried to enable remote connection until now (as far as I remember).  I bought this new a while back.
v2.4.21.938
Firmware v2.5.1.8
I get the following error in the Orbi Android app when connected to my Orbi Wifi (in Router mode connected to ATT gateway) and I go to Menu -> Settings -> Remote Management -> Enable Remote Management
"Something went wrong"
"This NETGEAR device is already registered with another account"
"Note: If you factory reset your router, you must re-enable remote management"
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: This NETGEAR device is already registered with another account
Where did you get your system from?
You'll need to make contact with NG support to help you with registration problems.
@Blanca_O
Message 2 of 3
Blanca_O
NETGEAR Moderator
Hi @successhawk
Welcome to NETGEAR Community!
Please send me a private message with the following information by clicking on this link :
Name
Email address
Device Serial number
Blanca
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1327 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
