Orbi WiFi 7 RBE973
Reply
Traffic statistics not working
murchman
Apprentice
Installed the Orbi router and satellite last night and everything is working really well except the Traffic statistics. I tried it with and without the traffic meter on and it remains at zero, I also notice the start date/time is way off on the statistics.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 12
murchman
Apprentice
Re: Traffic statistics not working
Update, I need a full reset and now it's working. Must have been an issue with the firmware update.
Message 2 of 12
Vandergraff
Apprentice
I have the same issue.
I am on the latest firmware and have re-booted the router.
Date and time is correct in logs
But if I enable 'traffic meter' that page says 'Current Date/Time: Wednesday,31 Dec 1969 04:04 PM'
If I disable trafic meter that page is now correct 'Current Date/Time: Saturday,24 Dec 2016 11:51 PM'
Ideas?
Message 3 of 12
Vandergraff
Apprentice
Any ideas?
Message 4 of 12
RonV42
Luminary
May be a bug in the firmware.  But you may want to check the time zone first in the advanced settings (see attached image).  If it is correct then I would suggest you open a support ticket.
Message 5 of 12
DarrenM
Sr. NETGEAR Moderator
Have you tried a factory reset like murchman he said that corrected the issue for him.
DarrenM
Message 6 of 12
murchman
Apprentice
I would do what I did a do a factory reset and start over.
Message 7 of 12
Vandergraff
Apprentice
Thanks - at this point I am thinking of putting the Orbi into AP mode.
WiFi coverage is stunning - but the router and app features / options are lousy....
Will go back to using an Asus RT-AC68 running asuswrt merlin as my router and the Orbi for WiFi.
Hoping Netgear will add to features and options in the future
Message 8 of 12
Vandergraff
Apprentice
One more go at this.
Did a factory reset and now can see traffic stats.
If I enable traffic meter it looks like the max monthly limit is 100,000 MB (100GB).
Comcast now has a monthly cap of 1 TB (1000 GB) - which I hate as a concept (as we all use more data 1 TB will become much more normal and comcast can monetize - we pay for a speed not a cap).
However it seems the Orbi can't check traffic above 100 GB?
Message 9 of 12
murchman
Apprentice
I have comcast as well and have gone over this month but wasn't using the router to limit the bandwidth. When I just tried to set it I see the problem you pointed out. I would start a new thread on that issue so hopefully Netgear sees it.
Message 10 of 12
swrtwdrv
Apprentice
Max can be set to 999,999 Mb
Message 11 of 12
Vandergraff
Apprentice
Good point - would still be good to have another digit as (hopefully) caps increase
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4580 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
