- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Trying to get 1 gig out of my Orbi WiFi connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just signed up with Comcast/Xfinity Gig service in the Houston area. I am using a Netgear CM1000 for a cable modem along with a Orbi RBK50/RBS50 system. The best I hve been able to get in WiFi is 350-400 incoming and 35 outgoing. The outgoing is what they limit it to so I can't change that. However the incoming falls way short. They have assured me that the modem is connected to the gig service. I have not plugged into the back of the Orbi yet. Is there limited to the Orbi or is it limits on WiFi?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the 2.4 GHz OFF makes no difference.
WiFi is inherently limited to 50-60% of the link rate. So, yes you can get more throughput if you use a combination of router and client device that both support a higher link rate than Orbi's 867 Mbps.
Orbi is designed for good coverage of a large area, not for peak speed for a single client connection.
Your Nighthawk claims to support a link rate of 2166 Mbps. This requires a client that supports 1024QAM modulation. It's unlikely you have a client that supports that. If you did, you'd need to use it very close to the router to get that link rate.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Trying to get 1 gig out of my Orbi WiFi connection.
Your Orbi WiFi is working properly at near maximum speed. Orbi's maximum link speed on 5 GHz is 867 Mbps. You will only ever see throughput of 50% to 60% of the link speed under ideal conditions, due to the overhead involved in the WiFi protocol.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So this is a limit in WiFi it self. Does it make any difference if the 2.5 GHZ is on or off. Also would it make any difference if I went back to my Nighthawk AC5300?
- Mark as New
- Bookmark
- Subscribe
- Permalink
