Orbi WiFi 7 RBE973
Reply
Trying to update Firmware on a RBS 50
Philpilot
Tutor
Trying to update the firmware on my RBS 50.  My router is now V2.3.1.60, the satellite is at V1.4.0.18 and will not update. trying to update to V2.2.1.212.img but it tells me that the formate is incorrect.  Driving me insane!
PCH
Message 1 of 9
Accepted Solutions
Philpilot
Tutor
Re: Trying to update Firmware on a RBS 50
I worked out later last night, I kept going back in updates until I found an update would take. Thanks everyone for your help.
Message 4 of 9
All Replies
What is the Orbi router involved here?
Is that up to date?
That is seriously old. Dozens of versions since then.
Try using something between that and the latest.
This can "unstick" things. There may have been an intermediate update that, like 2.3.1.60, needs an older version to make the leap.
Message 2 of 9
Guru
Download v2.0.0.74 and v60 for the RBS. Need to connect 1 wired PC to the back of the RBS. Factory reset the RBS by hitting the reset button for 15 seconcs then let go. Wait up to about 4-5 minutes. Your PC will get a IP address from the RBS. The IP address for it's web page should be 192.168.1.250 or .254. One of those input into a web browser will get you the web page for the RBS. Log in is admin and PW is password. Go to the FW update section and manually select the v2.0.0.74 file and up load it. Then you can directly update to v60 afterwards.
PCH
Message 3 of 9
Philpilot
Tutor
Message 4 of 9
Guru
Glad you go it working. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 5 of 9
Done. Nice to know that some of the old faithful solutions can still work.
Out of interest, @Philpilot, how far back did you have to go.
Wouldn't it be nice if the update process were a bit more intelligent and could spot those issues?
Message 6 of 9
Guru
v2.0.0.74 I found was the key to upgrading from v1x FW going forward.
Message 7 of 9
Philpilot
Tutor
I’m not at my computer at the moment, but it was the first V2.x.x.
Message 8 of 9
Thanks for the feedback.It might help someone who turns up with the same issue.
Sort of makes sense.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1969 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
