- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Turn off 5ghz WiFi channels
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi system with a Model RBR40 router. I am attempting to connect several smart home devices to my network. These smart home devices require that 2.4ghz Wi-Fi be used during setup with my mobile phone. As a result, I need to turn off the 5ghz Wi-Fi portion of my RBR40 Orbi Router temporarily to do the setup. Does anyone know of a way to shut off the 5ghz Wi-Fi signal in the Orbi router temporarily?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Turn off 5ghz WiFi channels
1. Just so you know, many of these 2.4G warnings are "Fear Mongering". I have five brands of smart switches and a Wyze camera that all insist, "MUST HAVE 2.4G", yet my smartphone was connected to the Orbi at 5G when I got all of them to work.
2. On the Orbi web interface, Advanced Tab->Advanced Setup->Wireless Settings there is an option regarding "Broadcast SSID". Uncheck that box for the 5G channel, and the Orbi stops broadcasting. Turn the phone off and back on and it should connect to the 2.4G channel. (I say should because I've never tried this. Never needed to.)
Hope this helps
p.s. there IS a method using telnet to completely turn off the 5G radio, but few people have needed it lately.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the advice from @CrimpOn doesn't work, try asking the people who wrote the installation routine for your smart home devices. Their programming landed you with this predicament.
You could also search this forum for messages about the devices you want to install. This issue crops up frequently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The IoT MFrs do not take in to consideration that since Smart Connect came out several years ago giving rise to the single SSID name configuration between the two frequencies, that the setup software they develop for there 2.4Ghz only devices only seem to develope there software for only the 2.4Ghz side of the SSID. IF they would take into consideration the setup mobile device that supports both frequencies and is both on the same side of the network, this would fix the main issue of there problems with users and router systems with deployed Smart Connect features. Thankfully NG finally gave there users the ability to temporarily disable the 5Ghz SSID so that users can get these IoT devices setup. This all falls on the IoT mfr.
