Reply
Highlighted
Retired_Member
Not applicable
Two systems, one network
I have an older home, that is split level (5 levels) and very long.  The ceilings and walls are rock lathe and plaster (1" thick).
Currently I have an Orbi system, but I am having signal issues with a 2.4 - N tablet that is one floor and two rooms away from the base.  I'm getting under 6 mbps and lots of throughput issues.  I have a CAT 5e line from one side of the house (office) to the other (in the garage).  It does run gigabit w/o any issues.
Would it be possible to add another Orbi system like this:
Office:
  • Router and modem
  • CAT5e run t9 Garage
Garage
  • Second Orbi Router in AP mode
Then I can place a satellite above each?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
Highlighted
NETGEAR Moderator
Re: Two systems, one network
Hello BrainJenkins
Yes you can do this but it would create a 2nd network.
DarrenM
Message 2 of 4
Highlighted
Retired_Member
Not applicable
Hi Darren,
Wouldn't I be able to use the same SSID?
Message 3 of 4
Highlighted
NETGEAR Moderator
You can but the devices will not automatically switch to each network.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1706 views
  • 0 kudos
  • 2 in conversation
Announcements
