Binketta's avatar
Binketta
Unable to Change DNS
When I log into the router menu, I am unable to access "Internet" (it is grayed out).  As such, I am unable to make changes to the DNS.  What can I do to access this screen?
Thanks for any help you can provide.
  • Binketta wrote:
    Hi, peteytesting. Thanks for responding.  The orbi is in AP mode.  As to your second question, I am taking a guess at what you are asking - it is connected to my ISP.
    ok first of all , in ap mode all router functions are bypassed including dns and many other features
    for beta testing in makes sense and logic to test in router mode , testing in ap mode bypasses many features
    are you here to beta test or get free stuff as AP mode achieve very little for beta testing
    pete
  • is the orbi in router mode or AP mode ?
    what is the orbo router connected to for internet ?
    • Binketta's avatar
      Binketta
