Orbi WiFi 7 RBE973
Reply
Unable to access admin account
Benjaminmalachi
Follower
routerlogin.net / routerlogin.com / 10.0.0.1 these options bring me to the orbi page but does not give me an option to enter my password instead an ad shows up for Circles and when i close it the browser is redirected somewhere else which just ends up with me getting a 400 Bad Gateway error.  http://192.168.1.1/ cant be connected to. I have tried Edge, Chrome, IE.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
schumaku
Guru
Re: Unable to access admin account
If true, the badly messed-up your Orbi model firmware ... probably not tested "what-if" the Orbi router is on a different subnet (like the default alternate 10.0.0.1 address).
Message 2 of 4
Smells like you have two routers on your network.
What is the modem in front of the Orbi?
Message 3 of 4
Guru
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
  3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 552 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
