Reply
Unable to access the admin page after firmware update
UP4278
Orbi RBR20 - After applying the most recent version of the firmware (2.6.1.36), my admin credential doesn't work. I went through input the router serial#. Then it asked input for 2 security questions, it doesn't like my answers. Unable to proceed..
What options do I have to reset the admin credentials and reset the security questions? (without factory reset).
Thanks much
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 8
Guru
Re: Unable to access the admin page after firmware update
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 8
fmalloy
Luminary
It's hearing stories like this that make me nervous about updating firmware.
Are you sure you entered the correct admin username/password?
Message 3 of 8
UP4278
100% certain. I used the correct admin password. (not entirely sure about the security questions).
Now it is a mess I needed to reinstall the entire thing. Smiley Sad
Message 4 of 8
Guru
Let us know how the reset goes. After setting up from scratch be sure to save off a backup of the configuration to file for safe keeping. Saves time if a reset is needed.
Message 5 of 8
UP4278
After the factory reset everything is back fine. All Circle settings were lost (annoying)..
I will not buy another Netgear device.
Message 6 of 8
fmalloy
Luminary
Advice around here seems to be a "factory reset" for so many issues. To me, forcing your device to be factory reset is an indication of poor design or firmware bugs.
A factory reset should need to be done only twice - at the factory, and when you sell it.
Message 7 of 8
Guru
To avoid settings being lost, the backup configuration to file is a feature that users can use to save a configuration to file. So after a reset is needed, you can reload the configuration from file and get your settings back.
Resets with ANY mfr router will clear out ANY user configurations. Nature of the beast and is a normal troubleshooting step.
Good Luck.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 430 views
  • 0 kudos
  • 3 in conversation
Announcements
