Orbi WiFi 7 RBE973
Reply
Unable to add Circle Plus for Orbi RBR50 router
Ptolemy1
Follower
Hi,
I bought the Orbi RBR50 a month ago and really enjoy the speed.  I have downloaded the Circle App, but want to upgrade to the Circle Plus.  The difficulty is, when I try to scan the QR code on the bottom of my RBR50, nothing happens.  There is a second method, that asks for a 17-digit code, which is longer than what is given for my Serial number or MAC code.  Those are the only two options given for getting Circle Plus, so I am at a loss of what to do.
Any advice?
Thank you!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Unable to add Circle Plus for Orbi RBR50 router
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1057 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
