Orbi WiFi 7 RBE973
Reply
Unable to install Orbi
willjeeler
Just bought Orbi Ultra Performance Mesh WiFI System - AX6000 - 2 pack - RBK 852.
Followed the installation directions.
Unable to connect to network.
I use AT&T fiber.  I have a Sonos system in my home.  Are those causing an issue?
Any help or suggestions would be appreciated.
Jill
Message 1 of 8
Guru
Re: Unable to install Orbi
Use a wired PC and web browser connected to the RBR and walk thru the setup wizard at orbilogin.com or 192.168.1.1. You may need to factory reset the RBR and start over with the PC and web browser...
Message 2 of 8
willjeeler
Looks like the modem is ATT - does not have another mfr name and model number.
How do I check the firmware?
Router is also a ATT BGW210.
What is RBR you are referring to?
Sorry, I'm not a super tech person at all.  But I can usually find my way through things.
I'm using a MacBook Pro and don't have the correct cord to wire direct into modem or router.
Appreciate the quick response!
Message 3 of 8
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
RBR = The Orbi router unit. RBS = Satellite units.
There are inexspensive USB C to ethernet adapters available.
Message 4 of 8
willjeeler
Ok.  I'll have to call AT&T.  thank you.
Message 5 of 8
Guru
Good Luck.
Message 6 of 8
willjeeler
Thanks.
Have decided to return it and go with another brand.
If I had known the installation would be that complicated, I wouldn't have bought it.
Appreciate your time.
Message 7 of 8
Guru
Good Luck.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 851 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
