- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Update firmware V2.3.1.60 outdoor Orbi stopt working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yesterday I was prompted to update to the latest firmware 2.3.1.60 for my satellite and base station. The RBR50 and RBS50. After the update I noticed that all devices that are connected to my outdoor satellite lost connection to the internet. Even after rebooting still lost connection.
So today I uploaded the older firmware 2.3.1.48 to the base and satellite. The outdoor satellite is still on 2.3.0.28
Via telnet I switched auto update off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Update firmware V2.3.1.60 outdoor Orbi stopt working
Try a reset on the RBR and setup from scratch after loading v60 FW. You can download v60 files from the download site now. After a reset, see if the RBSY reconnects, if not, try a reset on it and re-add it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply. I will try next weekend. The whole process takes some time. One of my satellites will never reconnect after an update. I have to do a reset and add him as new satellite to the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, unfortuneately it's a laborious process. It does help though.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
