- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upload and download speeds doesnt exceed 9.5 Mbps after RBK53 firmware upgrade to 2.3.0.32
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just have the ORBI RBK 53 from few days and was working fine. I found out about the firmware 2.3.0.32 and that it is resolving alot of problems.
As soon as I upgraded the firmware to 2.3.0.32, the upload and download speeds of the ORBI is not exceeding the 9.5 Mbps although my subscription is 50 Mbps and was working fine before the firmware upgrade. and this is using Wifi or wired ...
I tried alot of changes on the settings and restored factory settings but no results .
I opened a ticket with the support and worked with me for almost 40 minutes and still the problem persisted . They requested changes and told me it take few hours to take effect and to continue with them after 24 hours if the problem persist which something I dont get . ( i hope they can provide a solution today)
Does any one faced similar issues, is there a way to downgrade to the previous firmware ?
I am really frustrated as it is just newly bought, If the problem persist for another day, most probably I will return it back .
Apperciate any support here or recommendations to resolve the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upload and download speeds doesnt exceed 9.5 Mbps after RBK53 firmware upgrade to 2.3.0.32
Have you rebooted your modem from a POWER OFF state since upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A couple of questions:
- What equipment is the orbi plugged into (make/model)
- Can you post a screen grab of the ADVANCED ! ADVANCED SETUP ! WIRELESS SETTINGS page of your GUI?
- What kind of wired/wireless devices are connecting? (Type and how many)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Done the same with my old router and speed was normal.
Generaly i have 10 devices 8 wireless and 2 wired.
Wireless are samsung mobiles. Iphones and ipads. Fire tv.
Wired are Amcrest dvr and my old huawei router
- Mark as New
- Bookmark
- Subscribe
- Permalink
This may be part of the issue...
Are you running Orbi in AP mode?
If not, is that router before or after Orbi in the architecture?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router is after ORBI in the archtecture.
As highlighted before, I tested the speed without anything connected to ORBI .
Router is taking the internet services from ORBI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to change alot of parameters and retuned back then unplug the ORBI and SAT for 10 minutes from power and replug it to power and make it on.
The problem disappeared and returned to normal speed.
I dont know what solved the issue . I will update the forum if the problem returned
