Orbi WiFi 7 RBE973
Reply
Use my Orbi RBK50 as single point of connection?
Yogiwalsh
Follower
Hi, appreciate your advice.
I have installed and connected my Orbi RBR50 to my internet providers modem/router however I am experiencing some conflict (connection is not always stable) between the two.
So, can I get rid of my internet services modem/router and simply use my Orbi RBR50, only.
Many thanks,
Sean
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: Use my Orbi RBK50 as single point of connection?
No.  There is one specific model of Orbi that contains a DOCSIS 3.0 modem and can be connected directly to the cable feed.  All the other models require an internet modem.
Message 2 of 3
Guru
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Many thanks,
Sean
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 390 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
