Orbi WiFi 7 RBE973
Reply
Using Ethernet ports on the Satellite
dangitzin
New to the Orbi system. So the satellite has Ethernet ports... My question is, will I be able to connect a pc, console, or anything for that matter in the ports and have it be supplied with internet? Almost like a powerline adapter but instead the wifi internet shared to the ports?
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
Accepted Solutions
AC641
Luminary
Re: Using Ethernet ports on the Satellite
Yes, you can use it as you describe.  I have my Hue hub plugged into one of my satellite ports and have, in the past, had my laptop connected for testing puposes.
Message 2 of 4
All Replies
AC641
Luminary
Message 2 of 4
Roamabout
Luminary
It's witchcraft. They are creating wired ethernet out of thin air.
I have an old non-networked HP printer conected to an HP JetDirect print server and I have that plugged into a satellite ethernet port in a room at the upper back corner of the house.
Message 3 of 4
dangitzin
Thanks for the responses! I'll be cleaning up my set up this weekend(satellite is just sitting in the hallway upstairs).
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3119 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
