× We are experiencing login issues for several of our services. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com.
Reply
Using Gmail with an Orbi setup
creavy
I have managed to install Orbi in the house and wifi is working fine. However I am not getting my emails through Gmail. There is lots of technical speak about this but can someone please point me in the right direction to fix this (as an amateur) . All my family use Gmail so I will be sending the Orbi system back to Amazon if I do not get a fix for this today.
I'll have to keep watching this forum AS I CANNOT READ MY EMAILS!
Sean (unhappy!)
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 21
Accepted Solutions
creavy
Re: Using Gmail with an Orbi setup
All
I appear to have fixed the problem but don't ask me how. Everyne seemed to be suggesting I was have a dns problem. So I changed one of the dns switches in the Orbi app and suddenlt everything is working again including Gmail.
My thanks goes out to eveyone who took the time to respond to my issue and point me in the right direction. I don't understand any of these issues any better than before but it was the multiple suggestions regarding dns issues that made me look at my profiles and change the dns settings.
Thank you all. Without you I would have sent back the Orbi system to Amazon (to my/our detriment!).
Sean
Message 21 of 21
All Replies
OrbiMan
Luminary
So the only websites that you couldn't go to is mail.google.com ? Can you access all other sites? Including Google one like photo.google.com. Also what about other devices like smartphone can they access those sites while connected to wifi?
And also tell us how your Orbi is connected to the internet? Is it in router mode or AP mode.
Message 2 of 21
creavy
Hi Orbiman
It's worse than trying to get to the site for Gmail, I can't even get Gmail on my iPhone or any other app that is getting wifi from the Orbi. That includes Outlook on Windows 10.
The Orbi is is acting as my router (I used it to replace the Tilgin router supplied by our broadband supplier.
It just seems as if Gmail is ythe only problem we are having but it is all our email addesses that are effected.
Many thanks
Sean
Message 3 of 21
OrbiMan
Luminary
Only thing I could think of since it is one isolated site meaning there is something blocking it.
First open dos window use the window cmd command after opening try to command ping Gmail.google.com see if u get a response. Then try ping 172.217.3.46 that should be IP address for Google mail. Let us know what get
I am thinking your dns or something is wrong like a block
Message 4 of 21
creavy
Ping Gmail.google.com
64 bytes from 146.112.61.106: icmp_seq=23 ttl=58 time=17.155 ms
64 bytes from 146.112.61.106: icmp_seq=24 ttl=58 time=16.361 ms
Ping 172.217.3.46
64 bytes from 172.217.3.46: icmp_seq=1 ttl=49 time=90.913 ms
64 bytes from 172.217.3.46: icmp_seq=2 ttl=49 time=88.877 ms
64 bytes from 172.217.3.46: icmp_seq=3 ttl=49 time=89.275 ms
Message 5 of 21
st_shaw
Master
You have a strange problem.  It could be related to the router's MTU size.  Are you on a PPOE connection, or using some kind of VPN?
To check, try pinging using different packet sizes and the "do not fragment" bit set. It's the same test you just did with a couple options added.
See this: https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
Message 6 of 21
creavy
I tried but it didn't like the -f so I tried without and got the following
Seans-iMac-38438:~ seancreavy$ ping www.yahoo.com -f -i 1492
ping: -f flag: Operation not permitted
Seans-iMac-38438:~ seancreavy$ ping www.yahoo.com -i 1492
PING atsv2-fp.wg1.b.yahoo.com (46.228.47.115): 56 data bytes
64 bytes from 46.228.47.115: icmp_seq=0 ttl=55 time=24.171 ms
Message 7 of 21
creavy
Sorry - I forgot to mention I am on a PPPOE connection
Message 8 of 21
st_shaw
Master
OK.  That makes it more likely this is an MTU problem then.
What operating system are you testing on?
Message 9 of 21
creavy
All Windows 10, MAC OS and IOS
Message 10 of 21
creavy
Sorry I now assume which os I was using when I was running the ping tests. I was doing it on an iMac using MAC OS
Message 11 of 21
creavy
It is given me some options. Which should I use instead of -f and -i?
Seans-iMac-38438:~ seancreavy$ ping yahoo.com 1492
usage: ping [-AaDdfnoQqRrv] [-c count] [-G sweepmaxsize]
[-g sweepminsize] [-h sweepincrsize] [-i wait]
[-l preload] [-M mask | time] [-m ttl] [-p pattern]
[-S src_addr] [-s packetsize] [-t timeout][-W waittime]
[-z tos] host
ping [-AaDdfLnoQqRrv] [-c count] [-I iface] [-i wait]
[-l preload] [-M mask | time] [-m ttl] [-p pattern] [-S src_addr]
[-s packetsize] [-T ttl] [-t timeout] [-W waittime]
[-z tos] mcast-group
Apple specific options (to be specified before mcast-group or host like all options)
-b boundif # bind the socket to the interface
-k traffic_class # set traffic class socket option
-K net_service_type # set traffic class socket options
-apple-connect # call connect(2) in the socket
-apple-time # display current time
Message 12 of 21
st_shaw
Master
The commands differ between OS.  The link I posted was for Windows.
Also, because your issue is only with specific sites, you must ping the website or server you are having trouble with.  It looks like you were pinging yahoo or something in the last test.
Message 13 of 21
st_shaw
Master
Run it on Windows if you can.
And, it's -l 1492 not -i 1492.  That's a lowercase L! -i does something totally different.
Message 14 of 21
creavy
Many thanks. I'll run it on the one Windows PC we have got in the house (my wiife's using it to shop at the moment - if only it was was that part of the wifi that wasn't working instead of the email systems!)
Message 15 of 21
st_shaw
Master
LOL!  A router that limits the wife's shopping.  That would be a big seller!
Message 16 of 21
OrbiMan
Luminary
You have a strange problem, your computer seems to be able to ping website. You in theory should be able to access Gmail website. You sure you didn't accidentally blocked the website using some software or dns?
Message 17 of 21
st_shaw
Master
See this link where a user had the same problem.  The solution was, "I reduced the MTU of the router to 1442, and now I can can access all sites."
http://www.tomshardware.com/answers/id-2163967/access-google-google-related-sites-setting-router.htm...
I'm not saying this is definitely the OP's problem, just that it could be.
Message 18 of 21
creavy
Hi OrbiMan
How can I find out if I have accidently blocked the site with software or dns?
Sorry I'm a complete amateur so this sort of question is beyond me. I quite agree with you that I may have accidently switched something on or off without knowing what I was doing.
Kind regards
Sean
Message 19 of 21
TheEther
Guru
Ping 172.217.3.46
146.112.61.106 is the address for hit-adult.opendns.com.  Are you using OpenDNS domain filtering?  You may have blocked access to gmail with it.
Message 20 of 21
creavy
All
Sean
Message 21 of 21
Top Contributors
Discussion stats
  • 20 replies
  • 5332 views
  • 3 kudos
  • 4 in conversation
Announcements
